June 1, 2023 at 11:01 am
Lukas Walther
SubscriberHello im simulating methane combustion partially premixed (chemical equilibrium). Im analyzing the effect of diffrent pressures. One simulation is computed with 1 bar and the other one with 10 bar (mass fractions are the same). Boundary conditions are the same in bouth simulations.
According the literature the flame should be shorter under higher pressure, because the flame spread is accelarted.
Im getting the oposite....the flame under pressure is longer than the one under atmosperic pressure.
Why? ans idea?
Simulation (10 bar)
Simulation (1 bar)Heat release rate is plotted.
ThanksÂ
June 1, 2023 at 11:03 am
Lukas Walther
SubscriberPS: sorry for the scaled screenshots. bouth simulation are made with the same geometry and mesh
June 1, 2023 at 3:00 pm
Forum ModeratorCan you replot using the same heat release scale? It's hard to tell if there is a difference because we're not looking at the same thing.Â
June 2, 2023 at 7:17 am
Lukas Walther
SubscriberThe 10bar simulation has a 10x higher poweroutput due to the increased density. if i apply the scale of the 10 bar simulation to the 1 bar simulation u can hardly see anything.
June 2, 2023 at 7:25 am
June 2, 2023 at 7:28 am
Lukas Walther
Subscribernote: the hrr in this case is a named expression: Productformation rate * Density, not the default hrr of the pdf section.
June 2, 2023 at 9:14 am
Forum ModeratorNow compare the flame length: I can't easily do this as image size and position make it difficult. What gas density did you use?Â
June 2, 2023 at 9:36 am
June 2, 2023 at 12:33 pm
Forum ModeratorOn the above it's clear that the reported range is different too. If the report is product formation * density and there's a big density difference between the two models can we use that report as a metric?Â
June 2, 2023 at 1:53 pm
Lukas Walther
Subscriberyes i think it can be used as a metric
June 5, 2023 at 8:20 am
Forum ModeratorSo, next is check convergence and the assumptions in the model. How do the flow fields compare? Flame speed may be higher at high pressure (there's a curve as I vaguely remember doing it for my PhD) but combustion also required fuel & oxident to be in the right place at the right time.Â
- The topic ‘Flame comparison 1 bar & 10 bar CH4 combustion’ is closed to new replies.
5849
