June 24, 2023 at 2:26 pm
Agung Limowa
Subscriber -
June 26, 2023 at 5:25 am
Keyur Kanade
Ansys EmployeeCan you please provide more details here. What are you using? Is it Fluent Meshing or Ansys Meshing?Â
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
June 29, 2023 at 10:42 am
Agung Limowa
Subscriberi'm using ansys meshing and it has around 8 million cells but there is around 16 cells <0.1 in ortho quality, is it fine? i can' find a way to get rid of those cells
June 29, 2023 at 10:44 am
Agung Limowa
Subscriberi know that is <0.1 is bad but i mean is it really affected the calculation and giving some error or it just make the simulation less accurate ?
June 29, 2023 at 10:58 am
Forum ModeratorIt depends. If those cells are in regions with high gradients you'll potentially cause the solver to fail and/or produce poor results. If not much is happening you might get lucky and nothing bad happens.Â
- The topic ‘Fixing Bad Mesh’ is closed to new replies.
