February 3, 2021 at 10:35 am
TheHoang
SubscriberDear All
I am using Ansys 2016. My model include a beam is fixed at it' a head, and a force is at the other. When I solve, it error. Please see on picture. Can you explain why and how repair it. Thank you so much!
February 3, 2021 at 12:21 pm1shan
Ansys EmployeePlease share an image of the mesh. What kind of elements are you using? If you are using solid elements try to reduce the element size and remesh with few more elements in each direction.nnRegards,nIshan.nnFebruary 3, 2021 at 1:28 pmTheHoang
SubscribernHere are images of the the mesh.n
I sent them with a archive in link: https://humgedu-my.sharepoint.com/:u:/g/personal/nguyenthehoang_humg_edu_vn/EXN2Om3yRDtEsA7bSm-T_VsBpbwYF12O26l6hxyvqryUfQ?e=D42Lu3n
February 3, 2021 at 4:31 pm1shan
Ansys EmployeenTry inserting a mesh sizing control with at least 2 elements along each edge (z and x axix) and let me know if the error persists. You could also run a modal analysis to check whether the constraints look good or not. Large deflection also causes a pivot error in some cases. You could try reducing the load or adding a stiffer material.nnRegards nIshannFebruary 3, 2021 at 4:54 pm1shan
Ansys EmployeeAlso, Ansys staff can not download files from forum, so if you want to reach a larger audience to get answers from, please insert the images inline.nn-IshannFebruary 4, 2021 at 6:55 amTheHoang
Subscriber@1shannThank for your support!nI reduce size of mesh, it done. Your answer is useful for me.nViewing 5 reply threads- The topic ‘Fix error’ is closed to new replies.
4612
1515
1386
1209
