April 3, 2024 at 5:35 am
Aman Saini
SubscriberHey everyone,
I am trying to simulate a reconfigurable reflecting surface array in hfss. I have already carried out infinite array simulation using floquet port and lattice pair boundaries.
I want to excite the array with an incident plane wave coming from a certain angle, and plot the radiation pattern. Each unit cell in the array contains a diode modelled by series RLC boundary. I want to see the results for varying RLC parameters for each unit cell.
Can anybody please tell how to go about doing this?Thanks
April 4, 2024 at 1:08 pm
dushyant.marathe
Ansys EmployeeHi Aman,
Thanks for posting your queries on learning forum.
You can use a plane wave exciatation source to model a incident wave. This should provide you a directivity.
Regarding your second question, modelling the unit cells of array with varying RLC parameters for each, you may raise a service request to Ansys Technical Support and support engineer will get in touch with you to answer your query.
Thanks,
- The topic ‘Finite Array Simulation in HFSS’ is closed to new replies.
5719
