November 11, 2019 at 1:42 pm
JamesTheMech
SubscriberHi,Â
I would like to know how to find out how long it takes for a steady state thermal model to reach a steady state solution. I mean the theoretical time it would take for the model to reach equilibrium, not the time it took for the CPU to process the solution.
E.g. The metal bar heats up to a final temperature of 100degC after 4 minutes 2 seconds. At the moment my solution only tells me that the metal bar heats up to 100degC.
Thanks,
James -
November 11, 2019 at 9:33 pm
peteroznewman
SubscriberHi James,
Steady State Thermal is the solution after all changes over time have stopped and the system is in its final equilibrium state.
Transient Thermal allows you to take a thermal model with defined initial conditions, for example the body starts at 22 degC, and some boundary conditions such as all faces exposed to a fluid at 100 degC and solve the temperature as a function of time.
Peter -
November 12, 2019 at 10:03 am
JamesTheMech
SubscriberOk that's great; I'll give it a go. Is there a way to copy the load conditions which I have assigned to a steady state thermal analysis to a transient analysis which is using the same geometry. This would prevent me from having to reassign all the same load conditions again.
Thanks,
James
November 13, 2019 at 1:49 am
peteroznewman
SubscriberYes, in Workbench, just right mouse click on Steady State Thermal and Replace with Transient Thermal. All the assignments already made should remain undisturbed. You will just have to define an initial time step and an end time.
- The topic ‘Finding Time to Reach Steady State in SS-Thermal Model’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
3912
1414
1256
1118
1015
