January 1, 2025 at 3:28 am
Waqas
SubscriberDear all,
I have designed a wireless power transfer system, as shown in the figure below. I want to determine the phase along the line.Â
I am using this expression to calculate the phase.
I am observing a phase plot that fluctuates instead of showing a consistent -90 degrees between the transmitter and receiver in wireless power transfer (WPT) systems.
Best,
Waqas -
February 10, 2025 at 10:46 pm
MirandaH
Ansys EmployeeHi, what's the operating frequency?
February 21, 2025 at 2:39 am
Waqas
SubscriberThanks for reaching out. The frequency is 3 kHz.
February 14, 2025 at 4:22 pm
HDLI
Ansys EmployeeHello Waqas,
   You can write phase angle (x,y,z) to a file,
   "Complex > ComplxPhase", to get "Vec : Phase(
)" Â Â Â "Geometry > Line" to select line and "Output >Value" it, to get "VecLin : LineValue(Line(Polyline1), Phase(
))" Â Â Â "Output > Wrtie" to the file.
HDLI
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
- Classic Icepak – clarifications on Boundary condition
- Link the Circuit to 3D Terminals
- Rectangular Coil in Maxwell for WPT using solid block
- Magnetic Dipole moment calculation
4502
1494
1376
1209
