December 6, 2018 at 7:17 pm
Colleen
SubscriberI made a static structural study, and would like to know the stress and deformation values at an exact location to check if it matches strain gauge results from my physical validation.
I've been trying to create points from a coordinate file following this guide:Â However, it is proving to be very difficult to do this.Â
Could you please advise on the correct way to probe the results at an exact location for a static structural study?Â
December 6, 2018 at 8:03 pm
Sandeep Medikonda
Ansys EmployeeColleen,
 Please remove any references to sharcnet and use ANSYS Help. If you are not sure how to, please see here. Not only is this according to the rules of the forum, it is also more up to date and accurate.
 Coming to your question. Have you tried using named selections or construction geometry to do your post-processing calculations? Also, if you want to get an accurate representation of the Stress, you might want to use the ERESX, NO command. Please see this discussion.
Sandeep
Guidelines on the Student Community -
December 6, 2018 at 9:08 pm
Colleen
Subscriber Thanks for your response. I'm unable to view any of those links. The links to register with https://ansyshelp.ansys.com/ redirect me back to this site.Â
December 6, 2018 at 9:48 pm
Sandeep Medikonda
Ansys EmployeeWhat version of ANSYS are you using? If it is anything before 19, are you able to update? You can download the latest version from the first image on the top of this page. Help has moved online starting in v19.
Next, Can you confirm if you've followed the procedure listed in this article:
Sandeep -
December 7, 2018 at 10:44 pm
peteroznewman
Subscriber How many points are in your coordinate file Colleen?
December 11, 2018 at 6:41 pm
Colleen
SubscriberThere is only one point in my coordinate file, but I actually can't determine where the origin of the global coordinate system that was created by DesignModeler is, so I am not able to determine if my point is actually on a surface of one of my bodies or not.Â
Sandeep- thanks for handy trick. I can now access the ANSYS help system.Â
December 12, 2018 at 12:20 pm
December 12, 2018 at 9:39 pm
Colleen
SubscriberOkay great, thanks. Could I please have a little more elaboration on how to use Named Selection to define a point? It's not clear to me from the guide you provided:Â https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v192/wb_sim/ds_NS_creating.htmlÂ
In terms of using a coordinate file to define a point, I'm currently trying to use the Point tool in DesignModeler to define a point. I found the coordinates of my point in Mechanical using the "Hit Point Coordinate" function. IÂ formatted them into a .txt file using notepad. When I generate the point, I'm currently getting this error from the point tool in DesignModeler:Â
Error: Failed to create points, probably due to feature dimensions
Context: Point Feature Point1
December 14, 2018 at 6:35 pm
peteroznewman
SubscriberPlease attach the .txt file that contains your points so I can try it out.
November 25, 2022 at 12:22 pm
ARVIND SINHA
SubscriberA thin circular disc is under constant pressure on its surface. It is fixed at periphery. I can find the maximum deflection using Ansys Workbench . I want to find deflection at an intermediate point between centre and periphery . How to do it in Workbench. I am using version 19.
- The topic ‘Finding Stress and Deformation Values at an Exact Location in Static Structural Study’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
3862
1414
1220
1118
1015
