3D Design
3D Design
Find script of existing geometry
    • magdalena.krainz
      Hello, I built a part using Spaceclaim. Now I would like to see the script that was made when the part was built. Is it possible to view the whole script even though the part was built not using the script editor?
    • Devendra Badgujar
      Hello Magdalena,
      If you have not using the script editor to record the geometry operations you are performing then it won't be able to view the script. You will have to turn on the record button in the script editor to get the script.
      Thanks,
      Devendra
  • The topic ‘Find script of existing geometry’ is closed to new replies.
