TAGGED: ansys-mechanical, fatigue, fatigue-life, life
October 20, 2023 at 7:14 pm
Prasanth Renganathan
SubscriberHello! I have the SN curve data for Al from MIL-HDBK. The plot lists the max stress over number of loading cycles for different R ratios. When entering the SN curve data points for each stress ratio into Ansys, do I need to do the math to convert the max stress to alternating stress based off the R ratio or can the software calculate alternating stress component based off the supplied R-ratio and max stress?
Thanks!
October 24, 2023 at 3:25 pm
Zoi Stavrothanasi
Ansys EmployeeHello Prasanth,
When adding a new material and importing the data to create the S-N curve the only stress available is the alternaitng stress. So you should tranform the max strsses to alternating stresses before importing them in the Engineering data tab.
Hope that helps!
Zoi
- The topic ‘Filling SN curve data for materials’ is closed to new replies.
4618
1530
1386
1209
