July 27, 2023 at 7:39 pm
SK Abdul Alim
SubscriberHi. I am a complete beginner at Ansys. I want to fill a solid square with hollow spheres. The patterning doesn't work here. I even tried doing each hollow sphere manually(Primitive->Sphere->Cut Material), but that doesn't work. What would be the effective approach to fill a solid square with hollow spheres?
July 28, 2023 at 5:14 am
Keyur Kanade
Ansys EmployeeCreate sphere. Do not use cut material option. Please use frozen option. Then use pattern operation. Then use boolean operation of subtract. Please make sure that you do not have tangential contact or point contact between any 2 spheres. This may lead to failure of boolean operations. You can also try SpaceClaim for geometry operations.Â
Please go through help manual for more detailsÂ
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
July 28, 2023 at 7:36 am
SK Abdul Alim
SubscriberThank you so much. It was very helpful!
- The topic ‘Fill a solid square with hollow sphere’ is closed to new replies.
3170
1014
956
858
798
