January 9, 2019 at 8:33 pm
Numb3rs
SubscriberHello,
As you can see , I have this error when I try to dowload the student version of Ansys . (19.2)
I tried to reinstall the software many times but nothing to do ..
This happens only on my computer ( MSI GL62M 7REX - Nvidia Geforce GTX 1050 Ti ) so I tried to download the whole file on an other computer and to transfer it to this one but it doesn't work ..
I need this software for one of my courses so I don't know what to do .. If someone has an idea ?
Enzo
January 9, 2019 at 8:45 pm
ANSYS_MMadore
Forum ModeratorHello Enzo,
Did you ensure that you extracted the zip file prior to trying to install? Could you provide the contents of this file? If it shows a size of 0kb, try deleting it and then run your install again.
%APPDATA%Ansysv192ProdConfiguninstall_data.data file?
Thank you,
Matt
January 9, 2019 at 8:58 pm
Numb3rs
SubscriberHello Matt,
Thank you for your answer .
Yes I have extracted it before the installation . ( The software works , I can mesh on fluent but as soon as I try to launch the solver it crashes ) .
The problem is that , I have no file named "uninst_data.dat" or "uninstall_data.data" .
January 10, 2019 at 8:28 am
January 10, 2019 at 1:34 pm
ANSYS_MMadore
Forum ModeratorDo you see any error when trying to solve? Can you share screenshots? It appears the install completed if you have gotten through the installation process, and the uninst_data.dat message is not relevant.
What files exist in C:ProgrammesAnsys Inc and C:ProgrammesAnsys IncANSYS Student?
Thank you,
Matt -
January 10, 2019 at 1:58 pm
Numb3rs
SubscriberFinally I reinstalled it from the beginning and now it works .
The same message appears during the installation but now I can launch the solver without any problem .
Thank you for your help .
Have a nice day!
June 16, 2020 at 11:55 pm
buchs29
Hello Enzo,
Thank you,
Matt
Matt I do not see the folder you sau=id to try and delete. When I try to download I get the "critical error" box but it doesn't come up with an error it just stays white. Please let me know
June 19, 2020 at 5:57 pm
tsiriaks
Ansys Employeebuchs29, yours is a different issue.
Please create a new thread and search some past threads for info/resolution on this issue. There have been quite a few of them this past month.
February 1, 2021 at 8:25 pm
alvaronblaz
SubscriberHello I have the same issue, I have extracted the ZIP and the install it, but when i try to run the installation this comes: n
But the installation was running anyway. The thing is that the program is not working because at the end of the installation it shows that there was a fatal error. Eventhough, the folder has been created and but I cant find the program.n
n
- The topic ‘“File not found: uninst_data.dat”’ is closed to new replies.
