3D Design
3D Design
File import and conversion to sheet metal
    • Roberto
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
      Hello Spaceclaim is a beautiful software very useful for importing external files and editing the files themselves thanks to its direct modeling. For files drawn in a certain way, however, it finds a huge difficulty in modifying the geometry in sheet metal mode. For files where there are junctions linked to each other ( as in the attached file), if I try to change the geometry I do not change it and it behaves incorrectly. It would be nice to be able to change the joints and drains of this type of geometries without problems. It would be nice if, after being converted to automatic sheet metal, it left a space between the joints and that the drains could be modified later. If you need more information please let me know   Best Regards
    • Charudatta Bandgar
      Hello Robert ,
      I am looking into your query, will get back to you as soon as possible.
      Regards.
    • Roberto
      Hello Charudatta Bandgar
       It's not urgent take your time.
      Thank you
      Hello Robert , If I understood correctly, after importing the step file it isn't recognizing the junctions. Just to understand, I created a sheet metal file with similar junctions and saved it as .step, after importing the file, and converting to sheet metal, it did recognize the junction. I will share your file with the experts and get their opinions on why this is happening. Regards.
    • Roberto
      It is corrected the problem is the one indicated by you.
      I give you the following information, the problematic files are the files created by Creo Parametric (example of the file I sent you).
      Best Regards
      Hello  Robert ,
      I have raised a bug ticket (Bug ID: 346658) for the developers to look into. I will get back to you as soon as I hear back from them.
      Regards.
    • Roberto
      Hello Charudatta Bandgar thank you very much. I am attaching another file where the same problem occurs. If the developers need more files to analyze they are at their disposal and I can send them. Have a nice day
        Thanks a lot, Robert ,
        I will send these files as well.
        Regards
    • Roberto
      Charudatta Bandgar Hello
      I'm sending you an email privately
      Best Regards
    • Roberto
      do you have any news?
      Best Regards
    • Roberto
      Got any news from the developers? Are they working on it?
      Best Regards
    • Roberto
      Still no news?
      Best Regards
        Roberto Sorry. I have no update yet, I will try to get more information.
    • Roberto
      Do you have any news?
      Regards
Viewing 11 reply threads
  • The topic ‘File import and conversion to sheet metal’ is closed to new replies.
