July 10, 2023 at 7:13 pm
Zaid Abd Al-Hadi
SubscriberI have two files, one with the extension (.dat) and the other (.cdb).
what is the difference between both files, how to use them, and from which one I can KNOW THE COMMANDS used to make the model?
thanks in advance! -
July 11, 2023 at 6:46 am
Sampat Kumar
Ansys EmployeeHi
.dat file – The .dat file in ANSYS contains the instructions and parameters to perform a simulation. it acts as a command file that the solver reads and interprets to carry out the simulation. You can use the.dat file to know the command.
.cdb file- cdb is a coded database file. includes preprocessing, boundary conditions, analysis settings, etc. no results are included in this file. it can be read into APDL and External Modal.
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v231/en/ans_prog/Hlp_P_INT3_3.html
Sampat
- The topic ‘File extension types and uses’ is closed to new replies.
