September 16, 2022 at 9:50 am
Bruno Good
Hi
Actuell we can transfer from and to Mastercam with the Spaceclaim Add ON Geometrie from Spaceclaim to Mastercam. Adjustable wit the 3 formats
AcisBinary / ParasolidBinary and Step !Â
Mastercam can open direct the Spaceclaimformat *.scdoc from Mastercam!
Is it a great devlopment when we can choose the transfer with the 3 Formats on Top and also a additional format without convert in other formats the direct
scdoc format over the icons?  This was very helpfull and the quality from scdoc is better than the other Fileformats.
Thanks for answer
 Router
September 19, 2022 at 2:29 am
Charudatta Bandgar
SubscriberHello Router
If I understand correctly, you are asking that the masterCAM addin can transfer the acisbinary/parasolid and step file. But the masterCAM tool itself can open scdoc file, hence the transfer should be possible directly with scdoc file, instead of having to convert to the neutral file format. Is my understanding correct? If yes, I will convey it to the concerned team and get back to you with more information.
Regards.
September 19, 2022 at 2:51 am
Bruno Good
SubscriberHi Charudatta
You understand it absolutly corrcet, and it was very helpfull, when we had this additional possibility to existing transfer formats.
Regards
September 28, 2022 at 5:52 am
Bruno Good
SubscriberHello Charudatta
Any news about the transfer?
Thanks for feedback
Router
- The topic ‘File export to Mastercam’ is closed to new replies.
6104
