January 22, 2024 at 9:28 pm
MD Rashedur Rahman
SubscriberI am trying to export Ansys motor-CAD file to Ansys Electronics Desktop for BPM machines. I used to do this since many years by VB files. Now, when i am exporting the MOT file it's showing inside the Motor CAD that the file export is done to the location but when i am searching for the VB file in that location, i don't find any files.Â
January 24, 2024 at 3:26 pm
Timos
Ansys EmployeeHello, in order to export the MotorCAD model to Ansys Electronics Desktop you should create a script.vbs and afterwards run the script in order to create the Maxwell Model. Also you should be able to find the file inside the location where you export the script.
January 24, 2024 at 5:34 pm
MD Rashedur Rahman
SubscriberI know this. But by doing so, i don't see any Visual Basics file is creating. I am trying with V-shaped Brushless Permanent Magnet Motor. MotorCAD version is 2023.2.1.
- The topic ‘File export error from Motor-CAD to Ansys Electronics Desktop’ is closed to new replies.
