3D Design
3D Design
File conversion
    • Johnson Adegboyega
      Please, I created a 3D design using ANSYS Spaceclaim, and the file is in the default *scdoc* format, but I want to convert it to *STL* or a *STEP* file format that I can work with in another software. I have tried going to the spaceclaim options to get this done, but it seems not to be working for me.
      Can anyone please explain how I can get this done?
      Thank you.
    • Devendra Badgujar
      Hello Johnson,
      Can you please confirm if you are using Student version of Ansys SpaceClaim? If that's the case, then geometry export is not supported with Student versions.
      Devendra
      Yes I am using the student version of the software
    • Devendra Badgujar
      Hello Johnson,
      Geometry Export is not supported for Student Version of Ansys SpaceClaim.
      Thanks,
      Devendra
  • The topic ‘File conversion’ is closed to new replies.
