July 13, 2023 at 6:29 am
nina.megier
SubscriberI have tried to conduct a parametric sweep, where the parameter is relative permittivity, in Maxwell. The mesh should be used from previous project. After succesfully running the simulation I wanted to look on the fields with View Analysis Result in ParametricSetup1 . Although I have clicked the option "Save Fields and Mesh" I cannot plot anything/no fields are saved, see plots
. What went wrong? -
July 13, 2023 at 2:23 pm
GLUO
Ansys EmployeeHello,
Please try rightclicking results >> apply solver variations.
GLUO
July 13, 2023 at 6:29 pm
nina.megier
SubscriberYes, I do this, I also see that the variation was succesfully changed/applied as I get in the lower part of the window a message. But the fields are not there...
July 13, 2023 at 8:41 pm
GLUO
Ansys EmployeeHi Nina,Â
Can you try the change variable value button on field calculator?
GL
July 14, 2023 at 10:19 am
nina.megier
Subscriber -
July 14, 2023 at 1:55 pm
GLUO
Could you let me know if you are able to create field plots for other variations, and also what version of AEDT you are using?Â
GL
July 17, 2023 at 8:50 am
nina.megier
SubscriberÂ
I am able to create plots only for the first variation and I am using version 2022.2.
- The topic ‘Fields from Parametric Sweep with copied mesh’ is closed to new replies.
5754
