FGM Flamelets in LES
    • can.sumeyye
      I am setting up a transient LES combustion simulation in Ansys Fluent 2021 R2 and would appreciate clarification regarding the two nonadiabatic FGM options.
      My current setup is:
      • Partially Premixed Combustion
      • C-Equation
      • Flamelet Generated Manifold
      • Premixed Flamelet
      • CHEMKIN Physical Space
      • LES with WALE
      • Natural gas–air mixture at Ï•=0.8\phi=0.8
      • Fuel and oxidizer reference temperatures: 300 K
      • Pressure: 1 atm
      • Open-atmosphere Bunsen-type flame
      • Radiation disabled
      • Conjugate heat transfer disabled
      • Solid walls treated as adiabatic
      The production mesh contains approximately 5–8 million cells. Flamelet and PDF-table generation is performed separately on a small test mesh.
      My primary interest is the accuracy of the transient temperature field, particularly the temporal evolution of temperature at selected monitoring locations. Emissions prediction is not part of the present study.
      I am trying to understand the practical difference between the following three configurations:
      1. Energy Treatment: Adiabatic
      2. Energy Treatment: Non-Adiabatic
         Nonadiabatic Flamelets: OFF
      3. Energy Treatment: Non-Adiabatic
         Nonadiabatic Flamelets: ON
      My understanding is that in the second configuration, Fluent solves enthalpy transport and includes enthalpy as a PDF-table coordinate, but the nonadiabatic PDF is constructed from adiabatic flamelets under the assumption that species composition is independent of heat loss.
      When Nonadiabatic Flamelets is enabled, flamelets are additionally solved for different fuel and oxidizer enthalpy levels, so species composition, reaction-progress source terms and laminar flame properties may also depend on enthalpy.
      I would particularly appreciate clarification on the following points:
      1. For a case with no radiation, no CHT, adiabatic walls and equal 300 K inlet temperatures, how much difference should normally be expected between a fully adiabatic FGM calculation and a nonadiabatic calculation with Nonadiabatic Flamelets disabled?
      2. Does entrainment and mixing with 300 K ambient air provide any physical reason to use the nonadiabatic formulation, or is this cooling already represented through mixture-fraction and progress-variable variation in the adiabatic FGM table?
      3. For accurate time-resolved temperature histories and flame-crossing durations, can Nonadiabatic Flamelets = ON materially improve the result when there is no significant external heat-loss mechanism?
      4. Is the main benefit of enabling nonadiabatic flamelets limited to cases involving large wall heat losses, radiation, quenching, different inlet temperatures or temperature-sensitive species?
      5. What is the approximate computational impact of enabling Nonadiabatic Flamelets?
        • Increase in flamelet-generation time
        • Increase in PDF-table generation time
        • Increase in PDF/table memory
        • Increase in RAM usage during the main LES
        • Increase in wall-clock time per timestep after the table has already been generated
      I understand that the exact cost depends on the grid dimensions and number of stored species, but even a qualitative estimate or typical range would be helpful. In particular, does enabling this option mainly affect preprocessing, or can it noticeably increase the runtime of a 5–8 million-cell LES?
      In later stages, I also plan to repeat the analysis with approximately 10% and 20% hydrogen addition. Would hydrogen addition by itself make nonadiabatic flamelet generation more important for accurate temperature and flame-crossing predictions, even when radiation, CHT and nonadiabatic wall conditions remain disabled?
      My current concern is choosing the least expensive model that still provides reliable instantaneous temperature evolution rather than emissions such as NOx.
      Its a little bit long but I hope you can help.
Viewing 0 reply threads
