July 29, 2024 at 6:49 pm
Nick Pester
SubscriberHi,Â
I am running a LES combustion simulation. I am running a swirling, non-premixed combustion methane case. The case I am running is a stable flame from the experiment. I have initialized my LES simulation from a converged reacting RANS case (coupled+ Least-Square Cell-Based, Pressure: Standard, First Order Upwind for all other equations (2nd order doesn't show a stable flame). I have tried a lot of things, but the flame keeps dying. I have read a few papers that you guys have published recently and made sure I have the same setup but still same issue.Â
Any suggestions of what I could possibly do?Â
I am using the 22r2 version, would you recommend to change version and use the 2023r2? (I cant find release notes to see if there are any upgrades to the FGM combustion model).ÂÂ
Thank you for your help !!!
Below are my setup:
Fluent
Version: 3d, dp, pbns, pdf20, LES, transient (3d, double precision, pressure-based, 20 species pdf, large eddy simulation, transient)
Release: 22.2.0
Under-Relaxation Factors
Variable Relaxation Factor
Pressure 0.75
Density 0.75
Body Forces 1
Momentum 0.75
Energy 0.89999998
Temperature 1
Progress Variable 0.80000001
Mean Mixture Fraction 1
Linear Solver
Variable Solver Type Termination Criterion Residual Reduction Tolerance
Pressure F-Cycle 0.01
X-Momentum Flexible 0.1 0.7
Y-Momentum Flexible 0.1 0.7
Z-Momentum Flexible 0.1 0.7
Energy F-Cycle 0.1
Progress Variable Flexible 0.1 0.7
Mean Mixture Fraction Flexible 0.1 0.7
Pressure-Velocity Coupling
Parameter Value
Type SIMPLEC
Skewness Correction 0
Discretization Scheme
Variable Scheme
Pressure Second Order
Density Second Order Upwind
Momentum Bounded Central Differencing
Energy Second Order Upwind
Progress Variable Second Order Upwind
Mean Mixture Fraction Second Order Upwind
Below is the species model tab:Â
August 1, 2024 at 12:51 pm
Essence
Ansys EmployeeHello,
Try this out. This may help.
Please first complete the turbulence modelling and then move to reacting case. That is, first model URANS (non-reacting) case then switch to non-reacting LES. Once converged, then turn ON the reacting case and then radiation (if you need). Also, while turning ON the reacting case, I would suggest you to first run FR/ED with relax to chemical equilibrium with just one/two step(s) after turning ON the LES. Then using the EDM (relax to chemical equlibrium) as initial solution, switch to FGM and radiation.
August 5, 2024 at 10:25 pm
Nick Pester
SubscriberHi, I will try that! Thank you!
August 6, 2024 at 7:36 am
Essence
Ansys EmployeeYou are welcome. Sure, please try it out.
- The topic ‘FGM Combustion LES flame dying out’ is closed to new replies.
6835
1343
1152
