July 25, 2023 at 7:02 am
841563439
SubscriberHello everyone! How can I get a  FFT2D result of Radial Electromagnetic Force Density of Three-phase Induction Motor?I'll thanks a lot If one can give me a matlab script.
July 26, 2023 at 3:22 am
Reshmi Raghavan
Ansys EmployeeHello Peter,
FFT can be extracted directly within Maxwell. Please look for the topic of " Perform FFT on Report" in Maxwell help. Once you have the result extracted the Perform FFT on report option from Results can be used to extract the data.
July 28, 2023 at 8:29 am
Rosalie Nelson
SubscriberBe aware that running this script will result in an error if you have not already imported the data for the radial electromagnetic force density into a variable named radial_em_force_density. It is possible that you will need to make adjustments to the script in order to accommodate the data if it is stored in a different file or format.
- The topic ‘FFT2D of Radial Electromagnetic Force Density of Three-phase Induction Motor’ is closed to new replies.
