Feature Request: System Renaming
    • mergen.eric
      I have a feature request, hopefully this is the place to voice it.
      I think it would be great that if you rename a system in Mechanical, the system name is updated in Workbench too.
      For instance if I rename Static Structural (A1) in Mechanical to something like "500 pounds X", I would like the label under that system in Workbench to update and reflect that change. Is this already a feature? Do I have to check a box in somewhere in the settings?
      Renaming systems in Workbench is tedious. And if you've already renamed the system in Mechanical, it's redundant to have to rename it again in Workbench.
      Cheers,
      Eric
    • ErKo
      Hi
      We have noted that.
      For now, I have added a mech. script that can be run to do the above.
      Script is here:
      https://discuss.ansys.com/discussion/2609/in-mechanical-how-to-rename-analysis-based-on-names-in-workbench
      Any questions on scripts, post in the above link or contact your channel partner.
      Closing here as this might be useful to others.
      All the best
      Erik
    • ErKo
      Closing this as user has asked for Ansys support.
  • The topic ‘Feature Request: System Renaming’ is closed to new replies.
