July 16, 2024 at 10:50 am
NAMHYEON HEO
Subscriber -
July 17, 2024 at 8:31 pm
Dev
Ansys EmployeeHi NAMHYEON,
Tried increasing the simulation time?
The common cause is, the simulation time is not long enough, or the autoshutoff min is not small enough. Please significantly increase the simulation time, say 100 times more, and let the autoshutoff min to terminate the simulation and let me know the outcome.Â
Thanks annd regards
July 18, 2024 at 6:00 am
NAMHYEON HEO
SubscriberThank you for your response.
I tried increasing the simulation time from 1000 to 100000 and decreasing the AUTO SHUTOFF LEVEL to 1E-06, but I still get similar results.
July 18, 2024 at 9:02 am
Greg Baethge
Ansys EmployeeHi NAMHYEON, these oscillations are not necessarily wrong: as your substrate has a finite thickness, you basically have a Fabry-Perot cavity. You can easily check this using the STACK solver (see stackrt script command)
- The topic ‘FDTD transmission fluctuation’ is closed to new replies.
5729
