Photonics
Photonics
FDTD Sweep not displaying E Field data
    • Mike Neville
      I am trying to run a parameter sweep and record the E field data through a power monitor perpendicular to a dipole source. This data is recorded and can be visualised successfully when running an individual sim, but if not displaying when using a parameter sweep. I have checked the extraction pathway within the sweep multiple times and can confirm that it is correct. On top of this, when looking at the files the sweep generates, I can see the E-field data displayed within the monitor. Is anyone able to suggest a reason/fix for this problem?
    • Niki Papachristou
      Hi Mike,
      Thank you for reaching out to our forum. Do you get any error messages after completing your sweeping? If not, there is a chance that the result matrices are not equal (for example if you are sweeping on a varying geometry), hence you can’t visualize them all together. Can you reach each individual file on your folder with sweeps and visualize one at a time?
      Kind Regards,
      Niki
  • The topic ‘FDTD Sweep not displaying E Field data’ is closed to new replies.
