Photonics
Photonics
FDTD sample points in IR reflectance
    • woohokyeni
      I am struggling to handle the issue of having too few points in my reflectance spectra. Is there anyone who can help with this problem?
       I believe the number of sample points in the visible region are also quite small.
    • Guilin Sun
      You can increase the points to be recorded. and since you plot result vs wavelength, you should use "wavelength spacing".
      or you plot result vs frequency.
      Make sure the broadband is what you need exactly.
