November 16, 2023 at 11:30 am
simenew.assefa
SubscriberHi dear, I have tried to simulate the optical enhancement of Organic Solar Cells (PEHT:PCBM) by embedding Plasmonic nanoparticles using FDTD simulation. But I have got littel problem such as how can I work and run using Script file? and how can find the absorption of each layer of the divice /Glass/ITO/ZnO/Ag@SiO2/P3HT:PCBM/MO3/Al/? and during visualizing how can I fixe the color bar starting from 0 up to the last number, like I f iwant to fix the starting no. is zero with instep of 2 up to 8?
November 17, 2023 at 9:52 am
Niki Papachristou
Forum ModeratorHi Simenew,
Thank you for reaching out to us! The example that you are describing is something that you built yourself?
You can write the script commands at the script prompt or the sript file editor, You can find information about Lumerical scripting language - Alphabetical list here.
You can use the properties of the grapgs using the edit button:
Kind Regards,
Niki
November 17, 2023 at 2:23 pm
simenew.assefa
Subscriberthank you!
- The topic ‘FDTD Lumerical Solution’ is closed to new replies.
5729
