March 12, 2021 at 7:31 am
llingz
SubscriberHi,nI tried to simulate my final result but the simulation failed. nDetail shows: job aborted:n[ranks] messagen[0-1] terminatedn[2] process exited without calling finalizen[3] terminatedn[4] process exited without calling finalizen[5] terminatedn[6] process exited without calling finalizen[7-8] terminatedn[9] process exited without calling finalizen[10] terminatedn[11] process exited without calling finalizen---- error analysis -----n[2,4,6,9,11] on LINGZHI-LAPTOPnE:\lumerical\lumerical\bin\fdtd-engine-msmpi.exe ended prematurely and may have crashed. exit code 0xc0000005nn -
March 12, 2021 at 7:11 pm
Lito
Ansys EmployeeArray, Were you able to run this simulation before? Is this happening to all FDTD simulations? Check the simulation's memory requirements. Try to run the example simulation 'mwp.fsp' from the Applications Gallery (Apps).
September 1, 2021 at 4:55 pm
chuanx
Subscriber.Lito How do I check the simulations memory requirement?
chuanx
Subscriber.
September 1, 2021 at 7:09 pm
Lito
Ansys Employee -
March 7, 2022 at 9:46 am
Theo
Subscriber.I also meet this question when I changed the wavelength only.
When I used the wavelength of 1550nm, it can run normally.
But when I changed to 532 nm, it shows this error.
So, could you give me a hand?what should I do ?
March 7, 2022 at 6:19 pm
Lito
Ansys Employee.HLL,
Does the error happen to all simulation files including the examples from the Application Gallery (Apps)?
March 8, 2022 at 9:16 am
March 9, 2022 at 6:26 am
March 9, 2022 at 8:23 pm
Lito
Ansys Employee.HLL, Glad to hear this.
September 23, 2023 at 7:07 am
202016003
SubscriberWhen I use wavelength of 1500 micrometer the 3D simulation works perfectly but when I use 1.5 micrometer wavelength 3D simulation does not work.
Why??can somone help?
Viewing 10 reply threads
- The topic ‘FDTD error (exit code 0xc0000005)’ is closed to new replies.
