February 27, 2020 at 1:08 pm
Alex921
SubscriberI am modelling a turbine blade that has a constant rotational velocity and a cyclic pressure applied to it.
I want to calculate the life however I only need the cyclic loading applied to the pressure and not the rotational velocity. But when the fatigue tool is used, there doesn't seem to be a way to only apply cyclic loading to only one 'load'. Is there a way to selected which load it applies the cyclic loading to? Or is this not how ANSYS Mechanical works?
Cheers,
Alex
October 2, 2023 at 10:20 am
jxf200
SubscriberHi Alex,Â
I'm modelling something similar. Were you able to do it? If so, how did you define the fatigue tool?
Thanks,
Joan
- The topic ‘Fatigue Analysis with Multiple Loads’ is closed to new replies.
