January 7, 2021 at 5:03 am
Ramy
SubscriberHi,
I get this error (a screenshot attached below) when I try to "load results" in CFD-Post. The steps I do in details:
1- Open a separate CFD-Post tool.
2- Click "load results"
3- Select the last time step ".cdat" file.
Then I get that error. I don't even find that folder mentioned in the error. How can I solve this issue?
Thanks
January 7, 2021 at 6:44 amKeyur Kanade
Ansys EmployeeIs this error for this particular file or all files? It may happen that cdat file is corrupt. nCan you please do simple test case?nWrite .cas and .dat file from Fluent for a simple case. Then try to read in CFD-Post. nIf simple case also gives problem then there may be some installation issue. Please check if you can reinstall latest version available. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynJanuary 8, 2021 at 12:49 amRamy
SubscriberHi, nI installed the latest version and the same error occurs.nThanksnJanuary 8, 2021 at 6:41 amKeyur Kanade
Ansys EmployeeCan you please do simple test case?nWrite .cas and .dat file from Fluent for a simple case. Then try to read in CFD-Post.nPlease check this in standalone CFD-Post. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynViewing 3 reply threads- The topic ‘Fatal error in CFD-Post’ is closed to new replies.
5064
1770
1387
1248
