Fatal Error at end of Coupled Fluid-Struktural Analysis
    • Antonio Heck
      I want to simulate a deforming pipe and the alteration of the air flux in that pipe because of the deformation, and I have been able to do it.
      But after I increased the deformation of the pipe, this error came after the simulation concluded.
      Hear the Error (sorry for the Language doing the simulation in Germany):
      Translating: The Execution of the Coupling was completed successfully.
      After it completes, the Fatal error appears, and then it starts to try to exit but never completes; it needs to be forcefully terminated in order to try again.
      Has anyone any Idea what this error means or how to avoid it?
    • Federico
      I suggest going over the log files for each participant to get a more information about what caused this failure. For example, do you get Negative Volume cells in Fluent, etc.
      • Antonio Heck
        Hi
        I checked, and in both Fluid and Mechanical the Error was: “Hard exit for cases where the mesh flag is empty usually for debug NLAD runs.”
        or something similar,
        • Federico
          I don't expect Fluent and Mechanical to have the same outputs.
          Please check the latest .trn file for Fluent and .out file for Mechanical for any warnings or error messages.
        • Antonio Heck
          sorry for the delay
          thanks for the help i checked the files and in fluent was error negetav cell volume, i did the simulation again and strangely never had the error again.
  • The topic ‘Fatal Error at end of Coupled Fluid-Struktural Analysis’ is closed to new replies.
