December 4, 2021 at 1:16 am
Guilin Sun
Ansys EmployeeAnsys support engineers have authored a few hundreds posts scatted in the forum. With the increase number of posts, finding one post among thousands posts can be very challenge. I found it is more efficient by collecting them into one post. Ideally we can have proper categories. Due to too many posts and some posts are difficult to be classified, in this posts I just list them. Users can use Ctrl^F in this post to search some related key words. A collection of Chinese posts are here 如何有效地查看中文Ansys Insight 帖子
Rules & Guidelines — Ansys Learning Forum
Working with the Poynting Vector
Getting started in Lumerical Mode -FDE
Application Example: Quarter wave transformer
Rotating geometries in Lumerical's CAD environment
What is a "construction group"?
Interpolate finite element data onto a rectilinear grid
Bent waveguide simulation in FDTD
Setting about FDTD Region and mesh
How to set mesh order from script?
Calculating the absorption value
How to estimate the simulation time for an FDTD file?
Ansys Insight: Steps of Creating a Compact model for a Taper Waveguide
Ansys Insight: How to define an arbitrary figure-of-merit (FOM) for
Ansys Insight: How to set up KLayout-INTERCONNECT integration
Is it possible to simulate bent waveguide using EME?
Ansys Insight: Changes to polarization arrow
Ansys Insight: How to extract results from multiple simulation files
Ansys Insight: Importing arbitrary dispersive models
Ansys Insight: How to add new material into the optical material library Ansys Insight: How to add new material into material library (FDTD and MODE)
Ansys Insight: Spatially incoherent dipole
Ansys Insight: Spatial incoherence
Ansys Insight: Double slit experiment
Ansys Insight: How to measure power radiated by a dipole in a dispersive, lossy medium
Ansys Insight: Incoherent unpolarized dipole
Ansys Insight: Optical ports: Extracting s-parameters
Ansys Insight: How to get material data from material database
Ansys Insight: Diverging Simulations
Ansys Insight: General FDTD troubleshooting tips and tricks
Ansys Insight: Purcell factor calculations with an ultrafine mesh
December 4, 2021 at 1:17 amGuilin Sun
Ansys EmployeeAnsys Insight: How can the background material be changed in FDTD and MODE?
Ansys Insight: Simulating hollow or coated objects with mesh order
Ansys Insight: Constructing Setup/Analysis Script using script commands
Ansys Insight: Negative Q-factor
Ansys Insight: Measuring reflection
Ansys Insight : Measuring Reflection
Ansys Insight: Did my simulation stop before the auto shutoff minimum was reached?
Ansys Insight: CW normalization and source amplitude
Simulation time and frequency domain monitors
Ansys Insight: Key FDTD simulation settingsAnsys Insight: Key FDTD Simulation Settings
Ansys Insight: Transmission results greater than one
Ansys Insight : Visualize the CW response of a plasmon mode
Ansys Insight: How Parametrize your design
Ansys Insight: Data import and Export
FDTD Simulation with small refractive index - Silver
Creating 2D Conductivity from Permittivity Data
The Plasma (Drude) Material Model and some corrections to the model
Questions Regarding Autoshutoff level
Lumopt - Custom Figure of Merit
How to include propagation loss and coupling coefficient in ring resonator
Scattering from electric and magnetic dipole
Modeling MoS2 on Graphene using FDTD's 2D structures
How to simulate the charge distribution with unpolarized light
How to set the search index of the mode solver in EME with a script
Why does FDTD inject a pulse when I want a steady state, single frequency CW source?
Are deep level defects included in Lumerical?
Does Lumerical employ both Fermi and Boltzman statistics for laser simulations?
Can the finite time of Quantum Well (QW) capturing charge carriers be considered?
Which mobility models are available in Lumerical? Which tunneling models are available?
Is it possible to consider both laser generation and transport equations?
Can Lumerical simulate two photon absorption (TPA) and spatial hole burning?
Can I model the two photon absorption (TPA) effect in FDTD?
Convergence issues for FDTD simulation of plasmonic gold nanowire
Is there a material model that includes all nonlinear effects that exist for Silicon?
How can I import imaginary part of chi3?
Ansys EmployeeAnsys Insight: Getting material data from the material group
Ansys Insight: Small bent waveguide
Ansys Insight: Calculate the "Modal area" of a mode
Ansys Insight: How to define the refractive index of graphene
Ansys Insight: Tips for sweeping single frequency simulations
Ansys Insight: Scattering rate in surface conductivity of graphene
Ansys Insight: Single frequency CW source
Ansys Insight: Creating lossless materials
Best approach for simulating large ring resonators
Ansys Insight: Tips on running FDTD simulations
Ansys Insight: Calculating the response to an unpolarized beam
Ansys Insight: How close can monitors be to other objects
Ansys Insight : How close can monitors be to other objects?
Ansys Insight: Compiling your plugin material in Windows
Ansys Insight : Draw structure outline in visualizer
Ansys Insight: Custom TFSF source
Ansys Insight: About override mesh in FDTD Solutions: its use and settings
Ansys Insight: Difference between ''Maximum Generations'' and ''Generation size'' in Optimization
Ansys Insight: Why my simulation result is different from published paper or experiment?
Ansys Insight: How to correctly set the boundary conditions in FDTD simulations
Run large number of parallel simulations(reply to questions)
Ansys Insight: Slow convergence in FDTD
Ansys EmployeeTWLM Gain models
Ansys Insight: Defining doping in CHARGE
Ansys Insight: Convergence issues in CHARGE
Ansys Insight: Confinement factor in FDE
Ansys Insight: Boundary conditions and PML settings in FDE solver
Ansys Insight: Identifying the fundamental TE/TM mode
Ansys Insight: Simulation plane in 2D FDTD
Ansys Insight: GPU Devices
Ansys Insight: Diffusion doping parameters and their meaning
Ansys Insight: Can I simulate metal contacts with multiple layers in CHARGE?
Ansys Insight: Creating new ternary/quaternary III-V semiconductor materials
Ansys Insight : Lumerical products are now compatible with the Ansys License Manager
Ansys Insight: Choosing the most appropriate profile for PML boundary conditions
December 4, 2021 at 1:18 amGuilin Sun
Ansys EmployeeAnsys Insight: Releasing license stuck in 'Check Out' state
Running multiple Lumerical CAD instances on Linux
Ansys Insight: Running LUMERICL daemon with LMTOOLS on Windows
Ansys Insight: FAQs - Lumerical user, support, resources, install and licensing
Ansys Insight: Running parallel jobs using Intel MPI on Windows with Ansys LM
Resetting your Lumerical account password
Adding inbound rule to allow access to the ANSYS license manager on Windows
Checking license server status and license usage on the ANSYS license manager
Ansys Insight: Adding Lumerical PATH/environment variables on Linux
Ansys Insight: Adding Lumerical PATH/environment variables on Windows
Using multiple versions of Lumerical on the same machine
Installing Lumerical on non-graphical Linux systems
Ansys Insight: Multithreading in Lumerical Multiphysics solvers
Accessing Lumerical technical support
Running Lumerical simulation jobs remotely using MPI
macOS support ends with Lumerical 2020 R2
Ansys Lumerical entitlement activation and license file installation
Ansys insight: Fixing common Lumerical licensing errors
How to request a Lumerical evaluation license
Install Lumerical on SUSE Linux Enterprise Server
Ansys Insight: Run Lumerical simulations in parallel on Windows
Using Lumerical with X11 forwarding on Linux
Lumerical FDTD Simulation Benchmarks
Lumerical launcher or product Sign In
Installing Lumerical without root access on Linux
Ansys Insight: Fixing graphics related issues with Lumerical
Lumerical Microsoft MPI installation failed
Ansys Insight: Running Lumerical simulations in the background
Ansys Insight: Running Lumerical FDTD simulations sequentially
Lumerical FlexNet licensing error: -15
Ansys Insight: Determine the optimum resource configuration to run Lumerical FDTD simulations
Information on Hardware Specifications for Lumerical (FDTD)
Run Lumerical simulations using Intel MPI on Windows
Ansys insight: Fixing Lumerical Activation errors
Ansys Insight: Fixing MPI related 'Job error' when running Lumerical simulations
Installing Lumerical photonics simulation software
December 22, 2021 at 8:32 pmGuilin Sun
Ansys EmployeeAnsys Insight: Lumerical Multiphysics IDE fails to open on CentOS 8
https://support.lumerical.com/hc/en-us/articles/5634606863251-Installation-and-licensing-FAQ collections of installation and licensing issues and solutions
Viewing 5 reply threads- The topic ‘FAQs -search topics written by Ansys-Lumerical Engineers’ is closed to new replies.
4803
1576
1386
1242
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
