April 18, 2024 at 4:35 am
Houda ZHU
Subscriber一、Maxwell模型介绍:
Double-layered cylinders with top and bottom bases set to same direction COIL TERMINAL and adding WINDING, set to EXTERNAL, property SOLID, and REGIONAL OPPOSITION all set to 0.
(双层圆柱,上下底面设置为同向coil terminal,并加入winding,设置为external,属性为solid,region offset全部设置为0。)
Solution Type:Transient
Solve Setup:Stop time:30ms;Time Step:1us
Design Setting:Enable tr-tr link with twin builder
二、Simplorer模型介绍:
AC电源:
OUTPUTS:tick Use Pin\Voltage\Current\EMF Value,in Outplay\Display tick show pin and SDB
The input values are sinusoidal waveforms that are transferred from the SFunction of the simulink component to the simplorer.
(输入值为正弦波形,从simulink component的SFunction传输至simplorer中。)
三、错误信息:
error 11557 error encountered in the simulate function of user model. mode: FEA1.MAXWELL
error 13431 fatal error encountered while updating models. model:FEA1.MAXWELL
Adjusting the step size, HPC settings, etc. available on the internet have all been tried and never solved the error, so please take a look at what's going on!
(网上可查到的调整步长、HPC设置等方法都已尝试,始终无法解决错误,请各位看看什么原因)
April 19, 2024 at 3:16 am
HDLI
Ansys EmployeeHello Houda,
Could you just run Maxwell model to see if it works? then could you run the coupling between Simplorer and Simulink to see if it works?
HDLI
April 19, 2024 at 3:23 am
Houda ZHU
SubscriberHi there,
Maxwell 3D model runs well, and can output calculation results and generate tables normally. When only coupling between Simplorer and Simulink, the source signal from Simulink can transfer to Simplorer well and transfer back to scope in Simulink.
- The topic ‘Failure in co-simulation with maxwell 3D and simplorer.(maxwell和simplorer联合仿真报错)’ is closed to new replies.
6234
