November 20, 2024 at 9:55 pm
tr760256
SubscriberI ran into this error when generating surface mesh for our FSAE car
I've already checked the geometry and do all the repair and prepare steps, share topology for it. For fluent, I already did the sizing and pretty sure that I've applied correct sizing to capture everything. I've also read and do everything that this is recommended in this link  https://innovationspace.ansys.com/forum/forums/topic/fluent-meshing-error-3/.Â
Can anyone help me fix this problem?
November 21, 2024 at 6:57 am
Keyur Kanade
Ansys EmployeeIs this a single body or more than 1 bodies?Â
What file format you are importing?Â
Posting some images may help to understand issue better.Â
Please go through help manual for more detailsÂ
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
Â-
November 21, 2024 at 9:07 pm
November 22, 2024 at 5:23 am
Keyur Kanade
Ansys EmployeeHave you done share topology? Is it successful? Can you post image after share topology?Â
Why pmdb file? Are you using linux for Fluent Meshing?Â
Do you want solid + fluid mesh?Â
I can see you have solids as well as enclosure in the image.Â
Keyur
Â-
November 23, 2024 at 5:54 pm
tr760256
November 25, 2024 at 7:31 am
Keyur Kanade
Ansys Employeepmdb is required if you are using linux. You can directly import SpaceClaim file in Fluent Meshing. Please try this.
If you are using only single fluid volume to mesh, there is no need for share topology.Â
Keyur
3155
1013
956
858
797
