July 9, 2019 at 6:39 pm
rector
SubscriberHere is an email from one of our users:
I am trying to run the IE solver of AED and it is throwing the following errorÂ
  [error] Failed to check out license 'hfssie_solve'. License server does not support this license (FLEXlm Error -18) (10:14
9 AMÂ Jul 01, 2019)
  [error] Simulation was terminated by license error. (10:14
9 AMÂ Jul 01, 2019
He is using remote desktop into a window 2016 server. Any Help to solve this issue would be appreciated!
July 9, 2019 at 6:41 pm
ANSYS_MMadore
Forum ModeratorHello,
Please modify the license options.
In the current version, an HFSS license can be used to run an HFSS IE solution. To do this go to 'Options' tab of 'HPC and Analysis Options' > set 'Use legacy HFSS-IE license model' to 'False'.
Thank you,
Matt -
July 10, 2019 at 5:42 pm
July 10, 2019 at 9:10 pm
tsiriaks
Ansys Employeecan you scroll to the bottom ? Also make sure you select the 'Design type' to be HFSS-IE
what is the HFSS version you are using ?
Thanks,
Win
July 16, 2019 at 12:06 pm
rector
SubscriberThe user was originally using AED 2016.1, and the Use legacy HFSS-IE license model doesn't exist in that version. I've tried it also with 2019R1 and get the same error. Design type is set to HFSS-IE and Use legacy HFSS-IE license model is set to false, but still receive the license error.
I see there is another post with the same issue that states restarting the gui should pull the new license, but that has not worked in this case.
Thank you,
Steve
July 16, 2019 at 5:46 pm
tsiriaks
Ansys EmployeeCould you post the screenshot of your entire Electronics Desktop 2019 R1 GUI including the error message ?
- The topic ‘Failed to check out license ‘hfssie_solve’’ is closed to new replies.
3597
1273
1107
1068
953
