May 9, 2025 at 7:47 am
lq2556937429
Subscriberhello
When I use GPU accelerated 3D-FDTD, the mode expansion monitor shows “failed to calculate result”
The Lumerical version I am using is 2024 R1
If you need me to provide more information, please let me know
Looking forward to your answer -
May 9, 2025 at 5:47 pm
Kirill
Ansys EmployeeDear Subscriber,
Are you able to get results when running on the CPU?
Could you try upgrading to the latest version and check again?Best regards,
Kirill -
May 11, 2025 at 6:53 am
lq2556937429
Subscriberhello
During CPU acceleration simulation, each monitor produces normal results.
When GPU accelerates simulation, the mode extension monitor prompts that the results cannot be calculated, but the DFTM monitor, etc. can calculate the results normally.
Therefore, I believe this is just a minor bug in the 2024R1 version that is not as important (this issue can be resolved by resetting the mode to expand the monitor)
Thank you again for your attention and support
3049
971
900
858
792
