June 18, 2020 at 1:03 pm
June 18, 2020 at 1:56 pm
SaiD
Ansys EmployeeHi,
You should be able to apply a Bearing Load on the inner surface of the cylinder if it is a solid body. Bearing Load cannot be applied if it is a shell.
Also, if the CAD system split the cylinder into two or more faces, you need to select all the faces when defining the Bearing Load.Â
For additional information, go through:Â https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/wb_sim/ds_Bolt_Load.html?q=bearing%20load
Sai
June 18, 2020 at 1:57 pm
Wenlong
Ansys EmployeeHi,
What you did seems right to me. Can you please try close and reopen Mechanical, and try to apply bearing load again?
Just for your reference, a detailed documentation about how to use bearing load can be found here:Â https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/wb_sim/ds_Bolt_Load.html?q=bearing%20load
Wenlong
================ Note ====================
If you have trouble opening the links I attached, please see the first useful link below
Useful Links
- How to access Ansys Online Help Document
- How to show full resolution image
- How to use Google to search within Ansys Student Community
June 18, 2020 at 2:26 pm
FaezWahid95
Subscriberi have assign and select that two faces but the 'Bearing Load' option can't be choose
- The topic ‘Failed to assign surface/geometry into ‘Bearing Load’ outline’ is closed to new replies.
3757
1333
1168
1090
1014
