fail in importing agdb file to ansys meshing
    • Dato
      Recently , I have made my geometry into two parts to generate non-conformal mesh.When I plan to read in ansys meshing, it cannont read geometry and in "geometry imports",  it show red lightning as shown.
      By the way , I have sliced the geometry to generate expected mesh. In my geometry, some bodies have very close distance which is about 0.002mm. I don't know if it's caused by the tolerance . It's so weird that I have never met before. Your kindly help would be highly appreciated!!
    • Dato
      Addition: I open DM and ansys meshing at the same time. And I find it automatically operate share topology when importing it. It takes really a long time and finally it will fail. It's so weird that I successfully import this geometry from DM to ansys meshing and this time I just slice it to try better mesh.But it comes with this problems.
  • The topic ‘fail in importing agdb file to ansys meshing’ is closed to new replies.
