May 21, 2024 at 10:15 am
Keith Sequeira
SubscriberHiÂ
Im trying to model the flow of hot air out of a pipe and into a domain. Ive modelled the pipe in spaceclaim both with an open and close end and have built an enclosure around it. I'm trying to use the combine tool to subtract both bodies as ive heard it works to simulate flow leaving the pipe and not flowing through it. But i am facing an error " Unable to Intersect". I dont know what i could do to rectify this issues and to start with simulations. I am attaching a picture of the geometry i am to achieve and would appreciate any assistance on the matter
May 21, 2024 at 10:43 am
Devendra Badgujar
Forum ModeratorHello Keith,
From what I understand, there seems to be issue with how they have been modeled. You can refer this CHT Analysis in Ansys Discovery IGBT model to understand how to model this and how to create a flow domain.Â
From the image its difficult to find the inlet, outlet for your flow, if you can share a image of similar example to this in SpaceClaim will be better to understand?Â
DevendraÂ
May 21, 2024 at 10:53 am
May 22, 2024 at 1:56 pm
Devendra Badgujar
Forum ModeratorHello Keith,Â
When creating an enclosure around the bodies included those will get subtracted from he fluid directly. If you refer this Discovery SpaceClaim: Model Prep for CAE & MFG - Automatic External Volume Enclosure - Ansys Knowledge you will learn how to create external flow volume i.e enclosure in SpaceClaim.
From the image not sure how you will be defining the inlet and outlet. Fluid should enter that inlet and come out from it and than towards the outlet you highlighted right?Â
Regards,Â
Devendra
May 22, 2024 at 1:59 pm
Keith Sequeira
SubscriberHi Devendra,
Yes, the picture highlights how I would like air to leave the pipe. So I did try to subtract the model using the combine tool but was facing an error with interesecting bodies not being found. I'm not sure if it is because of the cushion values I've given to my domain.
May 22, 2024 at 2:03 pm
May 22, 2024 at 4:30 pm
Keith Sequeira
SubscriberThe video was very useful! Do you have any tutorials to mesh the same ?
May 27, 2024 at 8:39 am
Devendra Badgujar
Are you using Fleunt for this?
Devendra
- The topic ‘Facing Modelling Issues’ is closed to new replies.
6129
