Extraction of Linearized Stress Worksheet Results via Python Script
    • Gabriel Alves
      I need to extract the normal and shear stresses for a big number of nodes (which I have already selected) in Ansys Workbench 2023 R2.
      What I have been doing is manually export these stresses, obtained in the Worksheet Vew, since I have been simulating the linearized equivalent stress along the thickness of the plates that are part of my structure.
      I wanted to automate the process and obtain the spreadsheets for these Worksheets. I have come across the following Python script (found in https://blog.ozeninc.com/resources/using-python-to-export-tabular-data-from-within-ansys-mechanical) that works to automate this process but to export Tabular Data, not Worksheet.
      I tried changing the "TabularData" to "Worksheet" in the Pane variable but I couldn't get the code to work in any way. How would I extract the Worksheets via python scripting in Ansys Workbench?
    • Ashish Khemka
      Please see if the following link helps: Access to Worksheet Named Selection via Python console (ansys.com)
      Ashish Khemka
    • Gabriel Alves
      Hi Ashish. Thank you very much for the reply. I did come accross this discussion, but it didn’t help me in finding a solution unfortunately. I still need help with the issue explained earlier.
    • Gabriel Alves
      Hello Ashish. Hope you are well.
      Sorry to bother, but would you have any other suggestion or comment on the problem mentioned above?
      Thank you in advance.
    • Ashish Khemka
      Hi Gabriel,
      I have no additonal comments. Please wait for other members to comment.
      Ashish Khemka
    • Mike Rife
      Hi Gabriel
      As far as I can tell that specific worksheet has not yet been exposed for access.
    • Gabriel Alves
      Hi Mike. Thanks for the reply. I will try another around it then. Thank you!
Viewing 6 reply threads
  • The topic ‘Extraction of Linearized Stress Worksheet Results via Python Script’ is closed to new replies.
