November 2, 2018 at 7:12 pm
Sawan
SubscriberHello Members,
I have an array A (4 rows and 1 col), which contains numbers (eg. 15, 20, 45, 5). These number represent the element number of my meshed geometry. I want to select the the elements with these number i.e 15th, 20th, 45th and 5th element. I am using *do loop with esel command to select these particular elements but cant select all of them. My final purpose is to kill these element from analysis by ekill command. So this selection is necessary.
The code which i have for this task is:
esel,s,,,A(1,1)
*do,i,2,4,1
esel,a,,,A(i,1)
*enddo
PS. I know it can be done manually, but for the sake of simplicity I have presented this example. In real, I have an array with more than 100 rows.
Any suggestion for a better method to make this selection or improvisation in my way of doing it would help me a lot.
Many Thanks.
November 2, 2018 at 7:22 pm
jpasquerell
Ansys EmployeeInstead of a do loop you can use an implied do. It only works for the row subscript though.
esel,s,,,A(1,1)
esel,a,,,A(2:4,1)
November 3, 2018 at 4:13 pm
Sawan
SubscriberThanks. Works like a charm.
November 6, 2018 at 8:58 am
Keyur Kanade
Ansys EmployeeGreat. Can you please mark this as 'Is Solution' to help others on forum.
- The topic ‘Extracting values from an Array’ is closed to new replies.
- affinity not set
3967
1431
1272
1119
1015
