Extract only one model from an entire project
    • Samuele Luigetti
      Hello everybody, there's a way to extract and save ONLY one model of a workbench project with multiple models? If yes, how? Thanks
      In Workbench in the Project Schematic, right click on the Analysis block and select Export System from the popup menu.
      In a new or different project file, use File, Import to import the .wbpz file that was exported above.
  • The topic ‘Extract only one model from an entire project’ is closed to new replies.
