TAGGED: apdl, mechanical, moment, node, result-postprocessing
January 29, 2023 at 8:41 amstr35Subscriber
I'm trying to extract nodal forces and nodal moments using post-processing command.
I tried PRESOL command like below:
/POST1! Start the post-processing processÂPRESOL,S,Â! End the post-processing process/POST26ÂBut i got a warning message: "The geometry is not available. Â The PRESOL command is ignored."ÂHow can i extract nodal forces/moments node by node ?ÂThank you. -
January 30, 2023 at 5:56 amAshish KhemkaForum Moderator
Can you issue the SET command to select a relevant result and also issue ALLSEL, ALL to select everything?
Ashish Khemka
- The topic ‘Extract Nodal Forces and Nodal Moments’ is closed to new replies.
Ansys Innovation Space
- Ayuda con Error: “Unable to access the source: EngineeringData”
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- How to apply Compression-only Support?
- Geometric stiffness matrix for solid elements
- Image to file in Mechanical is bugged and does not show text
- Timestep range set for animation export
- Frictional No separation contact
- Script Error Code:800a000d
- Elastic limit load, Elastic-plastic limit load
594
591
540
366
