August 3, 2023 at 12:00 am
Cheyenne Hua
SubscriberI have a model with some joints (bushings to ground). I have several analyses in this model, in each analysis I have some joint probes that are telling me the joint force. I want to print the joint forces to a text file using scripting. First I was trying to just print the joint forces to the shell. I found this example to base my code on: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v221/en/act_script/act_script_examples_evaluate_spring_reaction_forces.htmlÂ
EXAMPLE:Â
# Get access to solver data analysis = Model.Analyses[0] solver_data = analysis.Solution.SolverData # Get access to result reader with analysis.GetResultsData() as reader: spring_results = reader.GetResult("SPRING") # Get a list of all springs springs = Model.Connections.GetChildren(DataModelObjectCategory.Spring, False) for spring in springs: print(spring.Name) spring_data = solver_data.GetObjectData(spring) element_id = spring_data.ElementId fForce = spring_results.GetElementValues(element_id) print(fForce[0])But it's for springs. Trying to change it to work for bushing joints, I don't know what to put here: reader.GetResult("SPRING") I tried "reader.GetResult("JOINT") but that does not compile. It does run if I keep it as "SPRING" but the results are nonsense. Please help! I could not find any documentation on the GetResult function.
Here is my code so far:
  joint_results = reader.GetResult("SPRING")
  # Get a list of all joints
  joints = Model.Connections.GetChildren(DataModelObjectCategory.Joint, True)
  for joint in joints:
    print(joint.Name)
    joint_data = solver_data.GetObjectData(joint)
    element_id = joint_data.ElementId
    print(element_id)
    fForce = joint_results.GetElementValues(element_id)
    print(fForce[0])I am using 2022 R1
August 3, 2023 at 6:27 pm
mjmiddle
Ansys EmployeeYou can show all available solution quantities using:
reader.ResultNames
A bushing can be chosen as MPC or bushing formulation. The MPC type produces MPC184 element and the bushing formulation produces a COMBI250 element.
For MPC type, you'll get these solution quantities from the bushing:
'BOLT', 'BOLTTOOL', 'BOLT_MPC184', 'CONTAREA', 'CONTDEBOND', 'CONTFNODE', 'CONTHNODE', 'CONTPNUM', 'ELEMENTAL_REAL', 'JF', 'JFL', 'JM', 'JML', 'JOINT_ACC', 'JOINT_DOMG', 'JOINT_OMG', 'JOINT_ROT', 'JOINT_U', 'JOINT_VEL', 'JR', 'JU', 'M', 'R', 'REULER'
Use "JF" to report the joint forces on the bushing:
jf = reader.GetResult("JF")
You can report the component types with jf.Components which returns ['X', 'Y', 'Z'].
When you use jf.GetElementValues(element_id), the values will be in global coordinate system. You can compare to a joint probe set to "Total Force" except this will report in the joint reference coordinate system.
- The topic ‘Extract joint probes with scripting API’ is closed to new replies.
