February 4, 2022 at 7:39 am
imtiazshuvo10
SubscriberFebruary 7, 2022 at 1:25 pmChinmay T
To get a high-quality model image please go to the "Modeler tab -> Export" in AEDT.
In the export file option, you can choose the graphic file formats like .png, .jpg etc. and in the image export option select the image size and save it.
Please refer ÔÇ£Exporting Graphics FilesÔÇØ section from HFSS Help document.
Thanks Chinmay
Viewing 1 reply thread- The topic ‘Extract high quality model images from HFSS?’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
Top Contributors-
3892
1414
1256
1118
1015
