TAGGED: ansys-apdl, ansys-mapdl, ansys-mechanical-apdl, apdl
February 17, 2023 at 1:32 pm
norbert.ionas
SubscriberHi,
Would like to extract the working load of a Bolt which has a pretension on it using APDL commands.
Thanks,
N
February 20, 2023 at 12:58 pm
February 20, 2023 at 4:31 pm
wrbulat
Ansys EmployeeHello Norbert,
I'd have to experiment with a test case to be absolutely sure this works, but I'd start by making sure that you save calculated nodal forces to the results file and set "Save MAPDL db" to "Yes" before solving. These settings are made in Analysis Settings Details.
Then, in a post processing command object, you could select the pretension elements and list forces using PRRSOL of PRRFOR:
resume
/post1
set,last
esel,s,ename,,179
nsle
prrfor
The reactions force listing would appear in either the solve.out or post.out file, depending on whether you run the create the post processing command object before or after solving.
Similarly, you could try this (if it works it'll show the net bolt load force in Details of the command object):
esel,s,ename,,179
nsle
esel,inve
nsle,u
esel,s,ename,,179
nsel,r,d,ux,-1e8,1e8
fsum
*get,my_net_bolt_load,fsum,,item,fx
Bill
September 24, 2023 at 9:15 am
1990chs
Subscriberhello, did you solve this problem ? -
September 25, 2023 at 6:19 am
norbert.ionas
SubscriberYes, I did. thanks
September 28, 2023 at 9:12 am
1990chs
SubscriberÂ
Can you describe the method?
If possible, please give the relevant APDL command.
Thanks.
October 4, 2023 at 4:07 am
norbert.ionas
Subscribertotal_nodes=0
ESEL,S,ENAME,,179 Â Â Â Â Â Â Â Â Â Â Â !select all pretension elements PRETS179
CM,bp_comp,ELEM Â Â Â Â Â Â Â Â Â Â Â Â !creates a component for the bolt pretension elements
NSLE,S,POS,3 Â Â Â Â Â Â Â Â Â Â Â Â Â Â !show/select head nodes for the pretension elements
CM,bphn_comp,NODE Â Â Â Â Â Â Â Â Â Â Â !creates a component for the bolt pretension head nodes
*GET,nr_nodes,NODE,0,COUNT Â Â Â Â Â Â Â !getting the number of head nodestotal_nodes=nr_nodes
*GET,NR_STEPS,ACTIVE,0,SET,NSET Â Â Â Â Â Â Â Â !get total number of time steps
*DIM,nids,ARRAY,nr_nodes,7 Â Â Â Â Â Â Â Â Â Â Â !array to store the forces
*DIM,bolt_force,ARRAY,NR_STEPS,nr_nodes+1 Â Â Â !array to store bolt forces*IF,total_nodes,GE,1,THEN Â Â Â Â Â Â Â Â !if at least one bolt pretension exist in the model
  *DO,i,1,NR_STEPS
    SET,,,,,,,i
    *GET,time,ACTIVE,0,SET,TIME
    bolt_force(i,1)=time
    *DO,q,1,nr_nodes
      column = q+1
      *GET,nodes,NODE,0,NUM,MIN        !get minimum node number
      *GET,nx,NODE,nodes,LOC,X         !gets x coordinate of the node
      *GET,ny,NODE,nodes,LOC,Y         !gets y coordinate of the node
      *GET,nz,NODE,nodes,LOC,Z         !gets z coordinate of the node
      NSEL,S,NODE,,nodes            !select the identified head node
      my_force = 0
      *GET,my_force,NODE,nodes,RF,FX      !gets the bolt force
      bolt_force(i,column)=my_force      CM,pproc_node,NODE            !creates component for the post processed head nodes
      ESLN                   !selects the pretnesion elements which are connected to the head node
      CM,pproc_sec,ELEM            !creates component for the post processed pretension elements
      my_elem=ELNEXT(0)            !select the first element from the list
      *GET,bpe_type,ELEM,my_elem,ATTR,TYPE   !get element type of the selected pretention element      NSLE
      ESLN
      !*GET,be_type,ELEM,my_elem,ATTR,TYPE   !get element type of the selected bolt element (issue with this approac when the bolt have two type of elements tetras and hex as they have different element id)Â
      *GET,mat_id,ELEM,my_elem,ATTR,MAT    !get material id of the selected solid bolt element
      nids(q,1)=q
      nids(q,2)=nodes
      nids(q,3)=mat_id
      nids(q,4)=bpe_type
      nids(q,5)=nx
      nids(q,6)=ny
      nids(q,7)=nz
      !unselect processed elements and nodes
      CMSEL,S,bp_comp
      CMSEL,U,pproc_sec
      CM,bp_comp,ELEM
      CMSEL,S,bphn_comp
      CMSEL,U,pproc_node
      CM,bphn_comp,NODE
      *GET,rem_nr_nodes,NODE,0,COUNT
      !/com, **rem_nr_nodes: %rem_nr_nodes%
      CMSEL,S,bphn_comp
      *ENDDO
    ALLSEL
    ESEL,S,ENAME,,179            !select all pretension elements PRETS179
    CM,bp_comp,ELEM             !creates a component for the bolt pretension elements
    NSLE,S,POS,3               !show/select head nodes for the pretension elements
    CM,bphn_comp,NODE Â
  *ENDDO
*ENDIF -
October 6, 2023 at 8:09 am
1990chs
SubscriberThanks, I will try.
- The topic ‘Extract Bolt Pretension Working Load with ANSYS APDL’ is closed to new replies.
5899
1306
