external pressure field as APDL-command in Workbench
    • hosis86
      Hi everybody,
      I'm building a model in Ansys where I should put a pressure field calculated in MATLAB on my structure. I use APDL-command in Workbench to do it. My question is, is it possible somehow to show the imported pressure field in Workbench so I can be able to check if everything is imported correctly? Cuz I can not be 100% sure about it by watching the results as deformation.
      Thanks!
Viewing 0 reply threads
  • The topic ‘external pressure field as APDL-command in Workbench’ is closed to new replies.
