November 20, 2017 at 11:16 pm
Jimmyhan
SubscriberHi, I am Jimmy, I have to input so many expressions in the simulation setting. sometimes I have input some constant and I have to add the equation when I tried to change the situation. So the expression list was in mess. It is so hard to find and change their value. How can I sort the expression list alphabetically or the sequence as I would like to
November 21, 2017 at 2:27 am
Min Zhang
SubscriberFor example, if you define expressions named as "Ux" and "Aux" respectively. Meanwhile, "Aux" is a function of "Ux", eg. Aux=Ux*5. In the Expressions list, "Ux" is displayed before "Aux".
~~~ You can right click the "Expressions" menu, and choose "Edit in Command Editor" to amend your expressions.
You also can create various CCL files to save your parameters, and import them automatically using session file (.pre). Notice: when import CCL files, choose "Append" Import Method.
November 21, 2017 at 5:26 am
Jimmyhan
SubscriberThank you for your reply, I understand what you mean. but can I change the sequence of expression?for example I want to input all the constant density, weight, viscosity......firstly, and input the equations. If I hesitated something I can just check the constant group or the equation group.
November 22, 2017 at 7:32 pm
raul.raghav
SubscriberI usually name the expression with "AA" in the front so its always easier to access them in the list. For example, instead of "fluidDensity", I name it as "AAfluidDensity". Not sure if that would be of use to you.
November 24, 2017 at 12:21 am
Jimmyhan
SubscriberThank you so much, It is a good idea!
- The topic ‘Expression sequence’ is closed to new replies.
5824
