February 17, 2025 at 2:01 pm
ito.r.bc
SubscriberI want to create a graph of magnetic flux density displayed on a plane, such as a rectangle, with the x and y coordinates plotted against the magnetic flux density. I only know how to do it using lines.
February 20, 2025 at 12:29 am
GLUO
Ansys EmployeeHi,
Maxwell cannot directly plot it. Please go to filed calculator, Choose Mag_B, copy to stack, then choose geometry, select the rectangle, choose Value to create a expresion like "SclSrf : SurfaceValue(Surface(Rectangle1), Mag_B)". Then use the write button to export it as .fld file. You can open it using notepad. The mag_B on this rectangle are listed and can be used to create plots externally.
GL
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Core Loss in ANSYS MAXWELL Eddy Current solution
- exporting and importing my Netlist for my external circuit
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
- simplorer-maxwell
1535
1386
1225
