TAGGED: #fluent-#ansys, dpm, particle, particle-deposition, particle-tracking
November 8, 2024 at 8:39 pm
DXS200048
SubscriberHi I would like to export particle history data like x,y z velocity and position on fluent. The availabe format when I click FILE>EXPORT>PARTICLE HISTORY DATA are are CFD post, fieldview, ensight and geometry. How do I export it in excel file? It should be simple but I couldn't figure it out.
November 12, 2024 at 1:43 am
nobrien
SubscriberYeah, the DPM stuff in Fluent doesn't give you a nice output like that in the file menu. You should try Results -> Discrete Phase -> Sample...
The menu looks like this. You can pick any boundaries in your model. It should write the x, y, z, u,v,w, Diameter, etc. of any particle that touches/crosses the boundaries that you pick. If there's a value you want to write to the file that is not with the default, you can write a user defined function and hook it to the "Output" in this same menu.Â
November 12, 2024 at 1:44 am
nobrien
SubscriberI should add that this will only export the particle landing locations; trajectories/tracks will not be exported. You could export tracks to a file using the fieldview format because it is all a text file, but you would need to write a script to go through it for your own purposes.
November 12, 2024 at 11:01 am
Forum ModeratorYou can also have a look in the Particle Tracks panel - there's a report function to give trajectory data.Â
5719
