July 27, 2021 at 4:58 pm
anouar000
SubscriberHello everyone;
I'm an intern and I'm working on a project about Corebreakage.
To export model and result to Ansys, I followed the procedure as mention in Autodesk help, the first is running the mpi2ans.vbs script to create the necessary interface files; the second is locating these interface files and using them in ANSYS.
The next step in Autodesk help is : (Locate the files that have been generated. These files are stored in the
Autodesk Moldflow Insight project directory where the interface files were created. Open the moldflow2ansys.db file in ANSYS and generate the required results using the ANSYS documentation for support.)
Can any one who already did this explain to me in details this step? (wich mean,how to view the result in Ansys).
Looking forward to your response.
Thank you for your help.
July 28, 2021 at 4:33 amKeyur Kanade
Ansys EmployeePlease do not create duplicate posts.
Viewing 1 reply thread- The topic ‘Exporting Modflow’s result to ANSYS by using MPI2ANS.vbs ?’ is closed to new replies.
