July 10, 2023 at 5:22 pm
Pouyan
SubscriberHello,
I have a question regarding exporting transient thermal data from ANSYS AM DED module. Specifically, I would like to export the simulation results, which consist of the full-field transient temperature distribution of the part. While I am able to export the temperature values for individual nodes at each timestamp manually, my requirement is to obtain the temperature data for all nodes across all timestamps, along with their corresponding locations.
I would greatly appreciate your assistance in resolving this matter. Thank you for your support!
July 11, 2023 at 11:33 am
Aniket Chavan
Forum ModeratorYou can right-click on a result and then create results for all result sets:
After this, you can automate the export using Python as mentioned in snippet here:
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v231/en/act_script/act_script_examples_write_contour_results_onto_file.html
-Aniket
- The topic ‘Exporting Full-field Transient Thermal Data in ANSYS AM DED’ is closed to new replies.
